Ok guys when i have my window up and driven down the street not noise. but when i put the window half way down or more the door rattles real bad..and it drive me crazy any suggestions..? or any help is needED!!
if you look just inside the window felt on the inside of the glass you will see a couple of "L" shapped brackets that have some padding on them, the padding on the brackets will compress and wear out over time, you may need to replace them. or, you may just have to adjust them so they are tighter on the window. to do so you will have to remove the door panel and then all will be explained.
NOOOOO, not the door panel, u have to remove the black trim piece that runs along the top of the door/door panel, make sure u use caution doing this it breaks easy, and do it with the window DOWN...
Ok...being that my piece at the top of the door has a crack in it anyways then what do I do after that?? is this it? the black at top of door?
yes that piece remove it then do as redbird said about moving the L shaped things
My door rattled like crazy when I bought the car. Didn't matter if the window was up or down. Took the door panel off and there was a huge pry bar in there. WTF? Anyways, you could have a loose window rail. I had that problem too. Matt
