door locks? part numbers and how to's?
Old Apr 6, 2003 | 10:41 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i need a new drivers side door lock and i was wondering how much they cost from gm? and anybody got any part numbers? and last how hard is it to change and how long will it take? thanks alot
Old Apr 7, 2003 | 01:01 AM
joshp14's Avatar
16608235 is the driver's side.
Best thing for you to do though is go to a local GM dealer and ask them for one with a key to fit it.
Old Apr 9, 2003 | 03:11 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
it is not that hard to change. the most time consuming part is taking the door panel off. all that holds the lock on is a metal clip. there's also a metal rod that you gotta take off the lock and then just slide the metal clip off and the door lock comes right out. i would see about getting a door lock that will fit your current key. If they can't do that, then you could either buy both door locks and one for the trunk all together or get a locksmith to make the new lock work with your key. I'm in the same boat i'm just 200 miles from my car so i can do anything with it yet.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
armybyrd
Aug 10, 2015 09:23 PM
