Door Panel Interchangeability.
Old Apr 27, 2003 | 01:02 PM
Joeboy's Avatar
I did a search but I coudnt find the info Im looking for. Im trying to find out which door panels are interchangable. I have a 82 Trans Am and Im looking at Door Panels on ebay. Will Camaro door panels and other year firebirds fit or what. Thanks in advance for any info.
Old Apr 27, 2003 | 02:07 PM
BTS88IROC's Avatar
They should all fit 82-92 camaro/firebird, I believe anyways, someone correct me if I'm wrong. The only difference will be if there are holes cut in the panels for manual windows and you have power windows. There are molded door panels too but you don't see those too often.
Old Apr 27, 2003 | 02:17 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Yes all Camaro and Firebird door panels are interchangeable. The only thing you need to do is make sure you get the right thing as far as power and manual windows go. That's it.
I have the molded door panels BTW. I wish I could find a set in perfect condition. I would be all over those. I don't like the regular door panels as much.
Old Apr 28, 2003 | 10:41 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
The flat door panels...Camaro or Firebird are interchangable!
Door panels like mine (molded) are not interchangable with flat door panels...the GTA style door panles are molded and take a different armrest...the metal support on the door is different! you would ahve to change this mounting plate and then they would work fine!
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
