weatherstrip Help please
Old Jun 6, 2003 | 03:21 PM
gigas's Avatar
Can somebody help me over here..i got a problem with what i need to buy for my inner door window weatherstrip... www.gmpartsdirect.com gave me 2 parts # 12394510(right) and 12394511(left) so i went to a chevy dealer to confirm and they are right..is one piece (window inner weatherstrip+support) also they told me that is the "only" part # for camaros and firebirds 82-92 but now is the problem..i went to http://www.yearone.com/serverfiles/h...p?hid=G20AE406 and i found that there is 2 kind...called back the dealer and they told me that there is only 1 so whats it going to be now???
Here i quote from year one
"Replacement door glass fillers and filler/run channel assemblies are available for 1982-1992 Camaros and Firebirds. All 1982 and some 1983-1984 models use a separate black filler panel, located at the front of the door glass, while other 1983-1984, and all 1985-1992 models combine the filler with the forward glass run channel. If you own a 1983-1984 model, inspect your original closely to determine which type your car uses."
TIA
Old Jun 6, 2003 | 10:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Click on the right part of my sig to find the most common part #'s you might need..
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
