My passenger side window hasn't been right since I bought the car. I went out today to have a good look at what was going on with it. What appears to be happening is that the rear of the windon is rising quicker than the front. However, when I loked at the front, there is a small rubber guide and the windos looks to be pressing to much into this, ad thus making the front stick and letting the rear rise quicker.
Does this sound familiar to anyone? Any help appreciated on how to solve this annoyance.
Rob
edit: windows are electric.
Rob
sounds like front or rear glass guide is out of place or weatherstripoping in one of them is messed up, you may need to remove door panel and get good flashlight and do some investigating, thats what i would do,o i gotta do same thing on driver side of the 82, the power window motor is not responding to switch, pink is hot and the blue and tan light up with tester when i press on one or other side of switch, and black is grounded, so all is good at switch, something flubbed in the door i assume, car been sitting not running for years, so i guess that can happen,. hehe, will be good chance to bearing grease the tracks and guides and undercoat inside door real good, it needs it to survive rainy salty crappy climate we get all winter long and spring even and fall too usually,,,,,,,,,,
good luck
good luck
