how to remove paint off...
Old Jun 16, 2003 | 11:09 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
i have an 86 z28. im preping the body for paint, when i saw that portions of the paint on the nose have been blown off. so now there are height differences on the nose. i tried using 80 grit paper to remove the rest of the paint off the nose but all it does is scratch it. anyone recommend a way to remove the paint so that i can get down to the plastic.
please help
86 z-28
90 block
4 bolt, 356
10:1 forged pistons, crane cam .510/.514
port poilished aluminum heads
t-5 manual trany
Old Jun 16, 2003 | 09:29 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
80 grit is to course to use on plastic-rubber I would recommend useing 180 to sand the old paint off and then go back over it with 320 grit and then you will need to prime with a high build primer to remove the scratchs
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wife'sCar
Aug 22, 2015 01:46 PM
Camarothatcould
Aug 20, 2015 08:49 AM
3rdgenparts
Aug 8, 2015 07:09 PM
