91 Firebird Front Fender & GROUND EFFECT
Old Jun 21, 2003 | 08:09 PM
MikeRush's Avatar
I'm replacing my front fenders on my 91 firebird, and I've gotten every single bolt out and disconnected everything. However, the ground effect that runs from the front wheel to the back is still attached after removing all the bolts. I think its apoxied to the fender but i'm not sure. Any tips on getting it off?
Old Jun 21, 2003 | 10:51 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Did you know that there are 2 screws that hold the gfx to the fender? You can get to em if you open the door, and peer down in the crack by the rear of the fender. I'm not sure if they're glued on besides that or not.
Old Jun 21, 2003 | 11:49 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The front fx are held to the fender by 2 nuts, accessible by removing the inner splash shield (plactic "inner fender") and unbolting them from the wheel well. You'll be hard pressed to access them via the gap through the door.
None of the GFX were bonded (that I know of) with adhesive to the car from the factory.
Old Jun 22, 2003 | 12:58 PM
Orinackra's Avatar
yeah, let me tell you how hard they to get to from the door. It never really dawned on me that you can get to em from the inner fender.
Old Jun 22, 2003 | 01:39 PM
patrickm00's Avatar
the only ones that had adhesive were the front fender-to-bumper parts, not the door sills or door panels. the adhesive was about a 1" strip, maybe 1/2" below the top of the GFX panel. you might be able to get at it from below with a large screwdriver, knife, or hacksaw blade. it's like a body tape, so it has some thickness. but be careful, i cracked one of mine at the front corner taking it off. i can dig around for it and try to take a picture if you want too.
Old Jun 23, 2003 | 09:24 PM
MikeRush's Avatar
thanks for the help i apparently missed the two bolts, but when i peeled back the fender far enough i was able to see them.
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
