ARG!!! How do i get the Door panel off?
Old Jul 20, 2003 | 10:26 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
OK, i took off the arm rests and the pocket thing and i can get the majority of the panel off, but there is one piece, the black hard plastic piece along the top, that i cannot get off? any idea's on how to do that.
Old Jul 20, 2003 | 10:37 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
The thing just clips in there. It's connected to the whole door panel itself. The best way I've found, is to roll the window down, (completely) and then push down and out at the same time. Just keep working with it. It has no bolts or screws that hold it in. It also helps if you have all the clips loose from the perimeter of the door, and the plastic around the door handles removed as well.
Old Jul 21, 2003 | 06:29 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
What if you can't get the window to go all the way down?
Old Jul 21, 2003 | 03:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
then it's a lot harder to take it off. You need to push the panel toward the outside as you come up with it, and obviously that is quite difficult when the window is there. It's still possible though.
Old Jul 22, 2003 | 09:45 AM
Car: 1987 Trans Am
Engine: tree-fiddy
w00t!!! we got it off of there yesterday, now the motor and arm was a biotch to get out but we did, and the new motor works, it just got dark before we could finish, so today we should have it all bolted back together.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
