Painting GFX
Old Aug 27, 2003 | 03:15 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Painting GFX
hey i did a search bt couldn't find what i need what grit sand papers should i use to paint my GFX? i am just going to rattle can them to match my car till i can afford a full paint job any suggestion i need asap going to get sand paper soon
Old Aug 27, 2003 | 08:59 PM
gilley's86's Avatar
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
Just wet sand them with any grit that is really fine. Might want to use spray paint primer and plastic spray paint or else if you just bomb can it, it could eat away at the ground effects.
Old Aug 27, 2003 | 09:31 PM
Dirty Rob's Avatar
Just used some fine grit sandpaper on mine when i had the camaro, cleaned em real nice, and spray canned em. Worked out fine.
Old Aug 27, 2003 | 09:39 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
400-600grit paper will leave the surface smoothe enough for painting.
Hotrodboba400
Dec 10, 2019 07:07 PM
snakeshooter
Sep 7, 2015 11:15 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
