thirdgen doors
Old Sep 12, 2003 | 10:05 AM
Cole's Avatar
thirdgen doors
Is there any difference between different years of thirdgen doors? I know that the stip on the door that's supposed to prevent door dings changed, but are all thirdgen doors pretty much interchangable (other than issues of ground effects and power windows and locks)?
Old Sep 12, 2003 | 10:18 AM
Briansz28's Avatar
Yes, they are all the same except for the ground effects holes. Even the power windows and the locks plug right into the car-side connectors. Interior panels are different. I swapped a '91 TA door onto my '84 Z28 and all I had to do was patch some extra holes from the TA ground effects. Power mirror is the same also.
Old Sep 13, 2003 | 11:05 AM
Tonyrodz's Avatar
Transmission: auto
I'm not sure how correct this is-but I was told by someone that some earlier doors weren't corrosion protected on the inside of the doors. I didn't really believe that tho.
Old Sep 13, 2003 | 07:34 PM
Briansz28's Avatar
It could be true! I gained my door knowledge because I had..... a rusty door!!
Old Sep 13, 2003 | 10:16 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
82-84 doors have different window tracks on the forward part of the doors. Also the older doors have a rust problem between the sheet metal and the outer belt weatherstrip
Old Sep 13, 2003 | 10:20 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The window mechanism and the triangle fillers are different in the 82 doors than in the 83-92.
Pete
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
BlackTopKing
Aug 19, 2015 12:13 PM
johanlindgren
Aug 15, 2015 08:37 AM
BrianI
Aug 9, 2015 11:52 AM
