Interior Door Handle Installation
Old Sep 15, 2003 | 01:21 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Mine broke so I had to buy a new one. How do I go about taking out the old interior door handle and putting in the new one? It will be going on the passenger side if that's important.
86 T/A
Old Sep 15, 2003 | 02:14 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you got the whole handle (handle + the bracket) there will be one large rivet (black arrow) you'll need to drill out to remove the handle assy. The pull rod should be self explanitory one you've started remove the handle. If it's just the handle lever, you'll need to grind the bottom of the pin off (white arrow) and simply swap the handles. The assy can be bolted or riveted back on. Just the handle would probably be easiest to just use a long bolt & nylon lock nut. Might be a better way.. that's just how I'd do it.
Old Sep 15, 2003 | 08:16 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Thats just how I did it couple of months ago. There's some real good threads on this including removing the interior door panel (the top is a little tricky) and remembering to lubricate your window glides while your'e in there also.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
1nastygta
Aug 8, 2015 07:38 PM
