Krylon Paint color
Old Sep 24, 2003 | 07:23 PM
Faded's Avatar
Car: '91 Firebird
Krylon Paint color
I'm going to paint all my interior plastic panels in my car from gray to black. I've searched this topic, and all the pictures I've seen of black panels it looks really really shiney. Do they make a flatter black too? Sorry I don't like my interior to blind me like my exterior does. =)
Old Sep 24, 2003 | 07:56 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
I painted my grill with "Exterior trim paint", it turned out flat black. It's exterior paint, so I bet it would hold up to the interior stuff
I'm not at home right now, so I don't have the exact brand name, but it was paint for exterior trim parts. (rattle can)
Old Sep 24, 2003 | 08:23 PM
Marlyn's Avatar
Have seen gloss black and satin black.
Most people use the gloss,satin would probably be what you want.
Old Sep 24, 2003 | 08:34 PM
91GunmetalRS's Avatar
Krylon makes Ultra Flat black and semi flat. Both are flat (I use em on model car kits) The ultra flat may be too flat, but the semi flat would probably be good. The best part is they are like $2.99 a can
Old Sep 24, 2003 | 08:54 PM
Faded's Avatar
Car: '91 Firebird
Sweet, thanks GunMetal. I think I'll find just one can of the flat, paint a kick panel and see how it turns out.
Old Sep 25, 2003 | 02:03 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
http://www.misterart.com/store/view....8420&store=003
Old Sep 29, 2003 | 04:35 PM
pontgta's Avatar
Car: 1990 TransAm GTA
Engine: 5.7 Tuned Port Injection
I do not want ot sound negative, but i would not recomend painting plastic interior panel. The paint will not adhere properly. The previous owner of my car had done this to one kick panel. I ended up replacing it with the proper color.
Old Oct 1, 2003 | 01:11 AM
onebinky's Avatar
It will stick as long as the panel is cleaned properly first. You have to chemically remove all traces of any oil, dust, dirt, armor-all, etc. Rubbing alcohol and then laquer thinner usually works pretty good. I would also use special interior paint, not just regular spray paint. The plastic panels are flexable, and most normal paint is not. If you push on the thin plastic panel and it flexes to much the paint will crack right off. It will also chip very easily, my guess is that it can't adhere to the plastic the same way it would to metal or wood. I'm pretty tired right now, so if something doesn't make sense tell me
Matt
Old Oct 1, 2003 | 03:24 AM
Faded's Avatar
Car: '91 Firebird
Lacquer thinner and plastic is a bad combination. That stuff will eat the plastic.
Old Oct 1, 2003 | 10:32 AM
onebinky's Avatar
Not if you don't soak it on. Just put a little on a rag and lightly brush it on the plastic. It will evaporate very quickly, taking only the armorall and crap.
angel2794
Sep 8, 2015 06:22 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
