Squeaky T-Tops
Old Oct 17, 2003 | 12:43 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
Squeaky T-Tops
Hey everyone, I have a 92 RS, with T-tops. they squeak a lot, most of the time I have the radio cranked too loud to hear them but when I have to ride quite, the tops squeak a lot! anny ideas on a quick and (cheap) fix? I put some silicon grease in there the other day but no change.
Old Oct 17, 2003 | 12:59 PM
MdFormula350's Avatar
try to tighten the screws that are on the t-tops.
i use spray silicon my myself, a good cleaning begoe with some water and a towel works great also.
U really need to look into subframe connectors, they made all kinds, bolt ons, weldons.
they help tighten the unibody up alot in that area to help reduce body flex.
a very good mod to do.
Old Oct 17, 2003 | 01:19 PM
camaro05's Avatar
Car: 91 Z28
going to get wonder bar in a few days hopefully. and I don't want to sink a lot of money into my car, I have a friend who wants to buy it and I want to get a 91-92 Z with a 350 or 305 tpi that I can swap out eventualy and mod (sfcs, stb and suspension ect...) when I make more money.
Old Oct 17, 2003 | 03:51 PM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
Use Vaseline to coat all the rubber weather seals...it will lubricate them and soak into the rubber a bit to keep them soft. The squeaking comes from them losing the petroleum in the rubber over time, thus becoming hard. If you go a little heavy on the Vaseline, it will definitely not hurt anything. Do it to the door seals and hatch seals at the same time, you will notice a big difference.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
