Greasing power windows
Old Oct 24, 2003 | 12:22 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Where are all of the pivot points for the passenger side power window? Mine starts as quick as it gets, then slows like it's out of grease or something, and then goes back to normal again. I really am not sure as to where all the contact and hinge points are and what grease I should use on them. Also, I can't find the window motor relay either to replace that if that is what it comes down to. I've stripped the entire interior except the driver's seat and haven't found the bugger yet.
Old Oct 30, 2003 | 07:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Anyone here had this problem?
Old Oct 30, 2003 | 10:27 PM
onebinky's Avatar
If you take the interior door panel off, you'll see everything you need. There should be something like 3 tracks in there, and a huge half-moon shaped gear. You'll want to clean them with WD-40 and work them up and down a few times. Then lube em up with white lithium grease.
While you're in there, you might as well do the same thing to all the lock linkages and the latch assy.
Good luck,
Matt
Old Oct 31, 2003 | 12:08 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Already have the door panel off. Already have done the lock mechanism once, but should probably do it again. I know about the track and the sector gear and the guide tube, but I am pretty sure there has to be more pivot points than that.... And I guess it's a good thing I bought that lithium grease when I replaced the gear nut in the hatch motor...
Old Oct 31, 2003 | 12:09 AM
Engine: 2.7L V6
Axle/Gears: 4.41
BTW, onebinky, I noticed that you have taken the emblem off of the front of your Camaro there. How in the world do you do that?
Old Oct 31, 2003 | 08:52 AM
onebinky's Avatar
Nope, that's it as far as I know. It's all the angle of the tracks and stops that are installed in there that give it the curvature it needs to seal up. If the window is just gradually getting slower as it goes up, and you already lubed up everything then the motor is probably getting tired.
For the emblem, there are two 10mm sheetmetal nuts on the backside of it and then it lifts right off. Then you just fill it with urethane filler and sand it smooth
Take care
Old Oct 31, 2003 | 10:54 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Not quite like you said. It goes faster than slow than fast again as it reaches the top. I don't get it....
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
