Window Tinting
Old Oct 24, 2003 | 09:27 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Window Tinting
Whats the best way to take tint OFF windows, My hatch is tinted and I can't see anything out of it, I need to take the tint off. How might I go about this?
There are window defrosters on it
Old Oct 24, 2003 | 10:55 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Check out a search on window tint removal and you'll find a couple methods. Be careful not to rip off the defroster, unless you don't want it anymore. Good luck
Old Oct 24, 2003 | 11:38 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i heard spraying a mist of amonia? on it and wraping it up in a garbage bag while letting it sit for a good 24 hours most of which should be in the sun will make the tint just peel off.
Old Oct 25, 2003 | 12:16 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Ha.. I'm doing it now and will finish tomorrow. Use a spray bottle filled with warm soapy water. Yes, dish soap! That is apparently what is used to soften the glue to put the tinting on. Have some holes and tears in the tinting, did we? Same here. It sucks when you get tint that is purple and has holes in it, don't it? And you must have a razor scraper on hand. that will help to peel up the edge of the tint so you can peel that crap off in large pieces, and use it again to remove the glue, otherwise your side windows sound like s**t when you roll them down, and they like to stick as well.
Old Oct 25, 2003 | 12:38 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I took mine off the same way. Peeled the tint off and then had to remove the glue. Use the soapy water or the stuff that the tint company sells at Wal-Mart. The spray bottle helps to spread it in little particles that will stick to the glue and begin to break it down.
Bring a towel.
It's like scaping snot off of a window with a butter knife. Drips all over the interior and it is sticky as hell too.
Old Oct 25, 2003 | 12:48 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Mine didn't drip too bad, probably because it was cold. But, since I've stripped my interior anyways and have custom soundproofing (insulation, etc.) in the back hatch area, I don't have to worry about it.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
