radiator support bent
Old Oct 27, 2003 | 10:04 PM
blueballz28's Avatar
Car: 86 iroc z
Engine: 305 tpi
Transmission: 350 turbo
can some one help me ? my radiator suppoert is bent from an accident , its not bent that bad it bent about an inch in wards and my hood wont close . how do i bend it back with out goin to an auto body garage ? i heard i can tie a chain on the front and then tie it to a tree and pull back on the car and it should straighting back out , is that correct?
Old Oct 27, 2003 | 10:51 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
pulling on a part of your frame will cause you nothing but headache. Do yourself a favor and take it to a reputable body shop and get an estimate. At least then you'll know how extensive the damage is.
The last thing you want to do is go pulling on it and get it more twisted than it was before.
Old Oct 28, 2003 | 09:40 PM
jerseydomestics's Avatar
once its bent, it's never the same, unless you pay major money for a pro. i went to a junk yard and just cut one off for my 86 sc from an 87 f-bird. its no big deal, any decent sawzall will cut through the battery tray and frame like butter( they're disgustingly thin). take it some where and chisle off the frame ends and any fender parts you didnt need. then simply find a welder and 10 mins later you have a perfectly fine support and surprisingly little cost ( for me only 15 for the support and 10 for sawzall blades and chisles).
Old Oct 29, 2003 | 03:18 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Unless your experienced in doing something like that, take it to a shop to have it fixed. You can cut and weld as much as you want on it, but you aren't going to be able to make it like it was b4. Trust me, I work in a body shop, unless you know what your doing and have access to the equipment(i.e. a frame machine) you won't be able to do it.
sheachopper
Jul 31, 2019 11:27 AM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
