Will a TA headlight fit my Firebird (different years)
Old Nov 3, 2003 | 02:59 AM
JUnderscore's Avatar
Car: 1986 Firebird
Engine: 2.8L MPFI (LB8)
I guess this kind of knowledge will come to me with experience...
I need to ask someone if they suppose an '84 Trans Am headlight assembly will fit into my [wrecked ] '86 Firebird.
I sort of found my answer in another thread, but not completely sure.
Thanks in advance.
Old Nov 3, 2003 | 11:53 AM
ONEFINE8T9's Avatar
it most certainly will, i had a wrecked 86 trans am, i went to a yard and got a headlight assembly and fit right up, if your still not sure call the dealer and ask them for a part number on both headlights, the broken one and the one you will replace it with.
Old Nov 3, 2003 | 12:43 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
Physically it will fit, but I have heard that the wiring changed around 84-85. Might not work properly without rewiring. Not sure.
Old Nov 3, 2003 | 12:59 PM
Car: 1986 Firebird
Yeah, I've read something about 2 wire vs 3 wire configurations. Does someone have more info about this?
Old Nov 3, 2003 | 04:26 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
If you need just the mounting/hinge assembly I think they are all the same for all 82-92. The motor however is a different motor. I'm not too sure, but I believe 87 they changed to the 2-wire motor. If you look at the two motors, the newer motor has one dimple in the **** while the older ones have 2 dimples in the motor.
Old Nov 3, 2003 | 05:44 PM
icebird_1981's Avatar
ya its the same if the wires are diffrent then just put the other bolb in.
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
