T-top rust repair
T-top rust repair
The t-tops on my 15th anniversary trans am are rusted pretty badly on the drivers side. it appears to be just a piece of metal that covers the main t-top support that is rusted it is black and has like 3 screws in it. I removed the screws thinking it would just come right out but it wont can someone please tell me what this is and if it can be removed and how. Also I need some rust repar advice. I have sanded some of the rust down. It is mostly surface rust. has anyone used Naval jelly ive heard it disovles rust but i want to know how good it is before i buy it. Is there a certain kind of primer i should put on once the rust is removed. sorry for all the questions, this is my first project car. She is a 1984 15th anniversary edition Trans Am. Needs a lot of work mosly body and interior. Any advice you can give me will be greatly appreciated, thanks.
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i had to fix the my leaking t-tops also on my 91 rs there is a nother screw under the weather stripping you will have to pull the weather stripping up on the side by the hatch after i found thoes screws i had to wiggle it to get off i had to buy all new weather stripping so keep that in mind hope it helps
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might do a search for POR-15. Many members, including me, swear by the stuff. Check the following link:
http://www.prp-porstore.com/
JamesC
JamesC
[MN] S&W 8 point rollcage
FueledSoul
Sep 30, 2015 09:18 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
