rear impact bar help?
Old Jan 20, 2004 | 11:42 AM
benoit454's Avatar
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
has anyone ever replaced their rear impact bar?
the metal piece that mounts to the end of the frame rails in back and then the impact strip or bumper recoil thing whichever u want to call it and the rear bumper cover mount to it?
mines rusted out somewhat and later when i add ground effects to my plain jane im goin to replace that since its rusted just wondering if it was welded to the frame tips or just bolts on
hopeing it bolts on thanks
Old Jan 20, 2004 | 01:46 PM
MNformula350's Avatar
I don't know about the back but i assume it's the same as the front, i changed my front one with an aluminum one (off a 4cyl car) and it was just 8 nuts 4 on each side.
Old Jan 20, 2004 | 01:56 PM
benoit454's Avatar
Car: 86 camaro
hmm i dunno i never knew there was one on front lol guess so?
i sen on the post about tuned port 355's restoration of an 87 z someone had asked him if hed changed his but he had guy put in pieces to cover old rusted ones
and i sen the padock and some other places sales the rear impact bar or bumper bracket almost since the bumper n pad mount on it guess u could call it a bracket thanks tho
Old Jan 20, 2004 | 02:01 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Yes, it bolts on just like the front one. Remove the 8 nuts and it comes right off. If you're changing to a Z28 look, just get a used Z28 impact bar with the plastic "eggcrate" impact absorber already mounted on it and put your Z28 rear cover over it.
Old Jan 20, 2004 | 02:33 PM
benoit454's Avatar
Car: 86 camaro
id have to get the zeggcrate to do it?
i couldnt just use the ones on car now?
because the impact bar bracket is rusted and goin get new one later for it and already have the z style rear bumper cover
thanks for the help
Old Jan 21, 2004 | 12:33 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You can use the non-Z 'eggcrate' with a Z bumper cover. The only difference in the Z ones, is they have a bit of a kickout on the bottom to fill in under the molded-on rear FX skirting. That little bit missing won't matter much.
Pete
Old Jan 21, 2004 | 11:43 AM
benoit454's Avatar
Car: 86 camaro
ok cool no big deal
ill do that later
cuz like i said im goin thru now just doin what i can to get it done and stuff to be able to be driven n look halfway nice
but itl loook just fine until it start rustin thru were ive patched the body w/ bondo
only spots on car rusted was like lil on bottom of front fenders and bottoms of doors was aweful and behind rear tires on lower 1/4 so they start goin this time im buyin replacement lower 1/4 pieces and goin get mig sometime soon and buyin another set of good doors from a z in a junkyard and shabing handles
so ill have all that taken care of n fixed right
and when i get ready to put on my shaved z doors the ground effects is goin on and rear bumper come off n replace that
thanks for all yurs help
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
z28addict8490
Aug 7, 2015 08:48 PM
