Manual Window Handle Part
Old Jan 29, 2004 | 01:59 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im missing my passenger side window handle for my door, I bought a new handle a while back but its missing that part of the whole setup the handle kinda latches on to, anyone know what this is called or where I can get it? If anything i'll take a picture tomorrow when I get out of work, thanks.
Old Jan 29, 2004 | 10:38 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I feel like I've seen this question once before.
Still not sure what part you're missing but, there are only 2 parts to a window handle. The handle and the horseshoe clip that holds it on...
Old Jan 29, 2004 | 12:19 PM
pasky's Avatar
haha, yea your probably the one who answered it last time but I still never knew what part it was, that crank hub is what is missing, i'll get a picture when I head home tonight, at work currently.
Old Feb 1, 2004 | 06:49 PM
pasky's Avatar
Here are some pictures.
Old Feb 1, 2004 | 06:50 PM
pasky's Avatar
Another one, sorry hard to get a good shot.
Old Feb 1, 2004 | 07:13 PM
deadbird's Avatar
Engine: TPI 305/ v6
This might be a stupid ? but, has the door been replaced ? The vapor barrior plastic seems to be intact as if there wasn't a window crank to begin with. As in, you have a pwr window door with the old trim on it. That's just a guess though mind you.
The part that's missing is not detachable from the rest of the regulator assy. that I'm aware of though.
Old Feb 1, 2004 | 08:14 PM
pasky's Avatar
Yes, I believe it was replaced because my passenger side side view mirror is way out of alignment, old owner said it never was but im suspecting it was. Anyway to get a hub on there?
Old Feb 1, 2004 | 08:35 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
The hub, or shaft the handle goes on to .. nope it is part of the window regulator.. pop your door panel off and take a look.. really sounds like you have a power window regulator inside..
Old Feb 7, 2004 | 06:22 PM
MikeS's Avatar
It does look like a power window door to me. So are you going to wire it up?
Old Feb 7, 2004 | 11:21 PM
pasky's Avatar
Depending on if I find a electrical drivers side or manual passenger side at the junkyard, i'd rather go manual then mess with the wiring but if I find a electrical i'll pick it up if the guy lets it go cheap.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
