head light switch questions
Old Jan 31, 2004 | 11:36 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
how do you take off the **** that you pull out to turn the head lights on for a 91 camaro because i am trying to put on a new gauge bezel
Old Jan 31, 2004 | 12:06 PM
3gc's Avatar
3gc
Car: Z28
If it's like the earlier ones there is a litle clip on the back side of the ****, you push it in and pull the *** out.
Old Jan 31, 2004 | 02:32 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
It's not like the old ones. There's a little round button on the bottom of the switch itself...you have to push the button in and the **** and shaft will come out together. The best way I've found is to take the knee panel off and use a long screwdriver or extension or something to push the button.
Old Jan 31, 2004 | 08:55 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
The GreatJ is right. There is a button on the bottom of the switch. Remove the knee panel and look up, you will be able to see it. The headlight switch must be in the on position if I remember correctly. Then push the button and remove the ****/shaft assembly. Viola!
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
