View Poll Results: which style
5 inch cowl
2.56%
SS style
18
46.15%
ws6 twin scoop ram air
12.82%
2 or 3 inch cowl
35.90%
Other (Post in thread)
2.56%
Voters: 39. You may not vote on this poll
which hood to go with
Old Feb 7, 2004 | 11:34 PM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
im debating on 3 different hoods right now...hopefully you can all help me decide...SS hood...ws6 style twin scoop ram air...or a 5inch cowl
Old Feb 8, 2004 | 03:56 AM
Kandied91z's Avatar
well i'm going to tell you bluntly that a 5" cowl is way to extreme for a street car and rediculous if you don't have the power to back it up.
between the options i'd say ss or cowl as the other is meant for a bird. while i know they make it for the camaro it does not flow with the cars lines in anyway possible and will hurt you in any shows or possible magazine coverage.
with that said i will also warn you about the actual process of getting the hood and fixing the hood. i have yet to see a fiberglass hood for our cars that didn't need work to fit properly and in most cases it takes alot of work to make it look really good. if your just building a race car and don't care about making it pretty i suppose it's of no bother but a good explanation of the amount i spent on mine should give you a good idea.
i have roughly 20 hours in fixing my hood and painting it, 5 of which is beyond normal for show purposes but the rest was just to make it look decent. it still isn't perfect which i'm not happy about but that's the manufacturers fault in the mold process. i would really like to know how some of these guys afford these hoods as i was lucky to get a discount on most of it along with the work i did but if i had to pay the right amount for everything i'd have almost 2500 in just a hood which is insane.
well either way good luck with your choice.
Old Feb 8, 2004 | 04:59 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
SS
Old Feb 8, 2004 | 07:29 AM
nolanr0413's Avatar
Car: Trans am
ram air , then get a 4th gen trans am wing for a thirdgen and put it on, and some sweet rims to complete the image.
Old Feb 8, 2004 | 09:00 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
3inch Cowl..
Old Feb 8, 2004 | 05:43 PM
Kandied91z's Avatar
i really think the 3" cowl would look sharp....the ss is nice too but pricey.
Old Feb 8, 2004 | 06:54 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Hell ya 5 inch cowl is rediculous. I have a bit of trouble seeing over my stock one sometimes. Not anything to complain about but 5 inches seems a bit overdone. Wouldnt a ram air setup work better than cowl anyway? I wouldnt go for the firebird one though. Wouldnt look right.
nate
Old Feb 8, 2004 | 09:04 PM
9T1 Z-28's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L TPI
I hate the looks of the SS hood. I can't believe ANYONE with a sane mind would EVER put one of those things on their car?!?
Old Feb 9, 2004 | 12:15 AM
Kandied91z's Avatar
the problem with "ram" air is that you have to be going fast enough to actually take advantage of it. purchase one of these hoods knowing that it will take a bit of work to make it look right, the only true performance you'll see is how much easier it is to open it and it will set your car apart from your neighbors.
Old Feb 9, 2004 | 12:25 AM
ramair92rs's Avatar
Car: 92 rs
Transmission: AOD 700r4
Unless you really need the hood clearance i would go with a 3inch cowl or less. I have a 4 inch cowl on mine and its hard as hell to see the whole road, but on the other hand it gives it a mean apperance, if only I had some mean power to go with the look.
Old Feb 9, 2004 | 12:32 AM
Pearl Jammzz's Avatar
Car: 89' RS
Engine: 2.8 V6
Depends on what u are going for, personally I would have to say the 3'' cowl. but only if it's cervini or glasstek hood though. the Harwood one I hear is ***.
Old Feb 9, 2004 | 10:04 PM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
AMEN
Old Feb 10, 2004 | 10:32 AM
lilthurmy03's Avatar
Car: 85 Camaro Z-28
SS Hood!! :rockon: :rockon:
Old Feb 10, 2004 | 11:48 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i personally like my 4inch glasstek, although if it was for a bird i really like glasstek's 3 inch cowl.....follows the lines quite nicely. and yes i know that side pic in my cardomain site shows the hood a little taller on the fender. that is just placing the hood on the car and shows initial fitment....which looks surprisingly better than any other hood i've seen....not to mention the pins aren't in the hood yet to pull it down on that side closer to the fender....with the pins in....it fits perfect.
Old Feb 10, 2004 | 12:28 PM
NEEDforSPEED's Avatar
It would be nice to see a pic of your car, that way i can determine which would look better, heh heh
Old Feb 10, 2004 | 02:29 PM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
heres the car
Old Feb 10, 2004 | 05:02 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Seeing the car now I have to vote SS. Anything else wouldn't look right.
Old Feb 10, 2004 | 06:36 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Transmission: fairbanks turbo350
heres the 4" cowlGlasstek hood. i just ordered the 5"cowl hood but i dont drive on the street very much.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
