hi-rise spoiler... add-on
Old Mar 3, 2004 | 12:00 AM
nathan2003's Avatar
Car: Camaro
k i have a 91 rs camaro with a fin spoiler on the back or whatever you call them and i just ordered and recieved the z-28 hi rise spoiler... i already have the hood blisters, and i'm changin front grilles and puttin in fog lights.... and new motor with 400HP is waitin to go in... so she be lookin z28 and be fast...
but anyways when i take off my fin spoiler what would any of you recomend to do to patch the holes... like if anyone here has done this, howd you go about that, and any other tips you might have!! thanks alot
Old Mar 4, 2004 | 12:25 PM
heather_52584's Avatar
Car: 87 Firebird Formula
i put one on my formula, so maybe the same procedure would apply. after i took my old aerowing off, i first put some plastic mesh in the hole the covered that with a fiberglass resin. after it dired, i sanded and then applied glazing putty. i let it dry, then sanded it smoothly. after i patched the holes and smoothed everything out i measured the hole position for my z28 highrise. i drilled the holes and installed it. then sent my car to the shop for a brand new paint job.
you should be done with the installation in about an afternoon. an extra pair of hands is useful when drilling and installing.
hope it turns out great!
Old Mar 4, 2004 | 02:52 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I just had a friend come over and weld the holes shut. Of course i already had acquired a hatch form the sema car that i got my high rise spoiler from, so we only had to weld the holes where the wraparound pieces were. After welding it, i just smoothed it down with a high speed grinder, but you gotta take it easy with the grinder not to get a lot of heat in the metal or it will start to warp ever so slightly. Any imferfections in the weld were then filled in with putty, sanded and primered. I can get you a pic of the finished corners if you like.
Old Mar 4, 2004 | 03:55 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Did you use the mesh pieces that they sell at like pep boys with the adhesive backing? Im thinking of going that route and using body filler since I dont have a welder. That will work right?
Old Mar 9, 2004 | 10:34 AM
i used some yellow mesh i found in my shop. it didn't have any adhesive. any mesh will work, it just gives the body filler something to hold onto. i hope yours turns out great, i love mine.
1992Z28!
Nov 19, 2015 07:33 AM
aaron7
Car Audio
Oct 11, 2004 11:43 PM
nathan2003
Mar 3, 2004 07:46 AM
flyin89
Sep 27, 2002 04:51 PM
True Power
Aug 24, 2002 01:57 PM
