Removing steering wheel
Old Mar 4, 2004 | 09:56 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
I am trying to replace the steering wheel on my 82 Firebird. The Haynes manual says to use a puller but I can't get one that suits. I live in Ireland so no GM dealers or parts here. I tried to make something to take off the wheel as there are two holes with treads each side of where the main bolt goes. I checked the sizes of these and they are some odd ball size like less than 5/16. So I can't get anything to thread into them. Is the steering wheel on tight?. Is it possible to get it off without a puller without doing any damage.
Any Help Appreciated.
Old Mar 4, 2004 | 10:09 AM
MNformula350's Avatar
In the past i have banged them off with a rubber mallet.
Old Mar 4, 2004 | 04:40 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
A harmonic balance puller will work. If you use a hammer you a liable to mushroom the end a little. I would say order one from a cat. or get a store to order one. The shaft is tapered so its hard to get it off without a puller. You can always re tap the holes wit a thread that you can find.
Old Mar 4, 2004 | 07:19 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 700 R4
I have taken a few steering wheels off in my time. the first 2 came off after i sprayed it with some PB Blaster and pulled and tapped it a little with a rubber hammer. The 3rd one, i had 3 guys pulling on it and it wouldnt budge so i had to use a harmonic balancer puller. Even using the harmonic balance puller was a struggle. it was really pressed on there
Old Mar 4, 2004 | 08:38 PM
MikeS's Avatar
I've made a little "puller" of sorts too. Just a bar with two holes spaced out to matched those threaded ones you mentioned. Place that across the center shaft and tighten bolts into the threaded holes. Have a lot of washers for between the heads of the bolts and the bar. As far as the bolt size goes, I'm pretty sure it is 5/16". It definately wasn't anything unusual. I just grabbed some bolts I had laying around. Probably a coarse thread, but don't hold me to that.
Old Mar 8, 2004 | 07:23 AM
gholian's Avatar
Engine: 2.8 V6
I got it off by tapping it with a Hammer and using lots of WD40. It took a bit of time but it eventually came free.
Thanks for you help guys.
Old Mar 21, 2004 | 07:18 PM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
just pulled off wheel myself . The two holes take a 1/4-20 screw.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
