Carpet Die.....
Old Mar 15, 2004 | 01:39 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Carpet Die.....
alright guys, just got back from walmart with 3 yards of black vinyl, and 1 yard of black fur(dont ask, not done yet). Since the new theme will be black, i wanna die the carpet. The only die they had seemed to me that it was the kind you put in the wash, liquid concetrade. My question is, can i put theis in a spray bottle, spray it on, ansd then wash it out? Or is this what your supposed to do?
Shane
P.S. if you got info hurry up and answer caus ei'm leaving ver shortly...
Old Mar 15, 2004 | 01:45 PM
crnsuperduty's Avatar
Car: 88 sc. convert
Engine: 305 TBI
Transmission: Formerly 700-Now T5
From What i hear, just mix it in a bucket, then pour it on the carpet and scrub it in with a scrubby brush (Like for washing cars). Basically let it dry in the carpet. Wash it out later and let it dry really good. Be sure to wash and dry the carpet really well before you start. I have a buddy that did it in his 68 Chevelle, he used Rit black dye. I will be doing my 88 convert in the next couple months. keep me posted on how it turns out.
Old Mar 15, 2004 | 02:23 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
I used Dupont Fabric and Vinyl spray on dye.
Worked damn good, you just need to do touch up every now and then. But cheaper then a new carpet (which I still plan on buying sooner or later).
Old Mar 15, 2004 | 03:29 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
I sure will tell you the results. I just gto back from walmart, got my die, and a few other things needed for my interior mods. I'm gonna recover the door panels, and the t-top mod has to be completed.....
Shane
Old Mar 15, 2004 | 03:37 PM
Car: 88 sc. convert
Engine: 305 TBI
Keep me up on the door panels. too. I'm trying to figure out how I'm going to do mine. I love flames cut into the panel, I'm sure I'll incorporate that somehow.
Old Mar 15, 2004 | 04:28 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
OMG door panels are hard as f*ck to do. Theres so much sowing and shizzle its not even funny. But it is coming along nicely, after spending half the day getting supplies, i have been able to start. Only 2 hours into it and alreadya 1/4 way through one of the door panels. There are coming lone nicely.....
Shane
Old Mar 19, 2004 | 04:55 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Just go down to the grocery store and get some Rit dye. Youll need about 5 packs to do the carpet and make it look good. Get an old windex bottle, use about one pack of dye per bottle of hot water, and spray it on. I did this on my carpet that was all faded, it worked great. Im just about done with my total interior restoration and ill have pics when i post about it.
Old Mar 19, 2004 | 06:17 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
already done. Used tiny spray bottle and the liquid die form. Only needed 2 bottles. which mean 4 packs of the little boxes.
from this
to this
Old Mar 19, 2004 | 06:35 PM
Faded's Avatar
Car: '91 Firebird
Is that supposed to be black?
Old Mar 19, 2004 | 06:53 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
With thnat die stuff i dont think you can relaly get it black. Can you??????
Old Mar 20, 2004 | 09:58 PM
Faded's Avatar
Car: '91 Firebird
Wait, so what were you trying to accomplish by dying it then?
Old Mar 20, 2004 | 10:02 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
it did come out black aftger all man check here,
https://www.thirdgen.org/techbb2/sho...44#post1744444
it sortas looks purple but it is really black
Old Mar 20, 2004 | 10:20 PM
Faded's Avatar
Car: '91 Firebird
alright, that isn't so bad. btw, your door panels turned out better than i thought they would after seeing them with the vinyl loose. If I were you though, I would have tried to put some more character into them by making some vertical creases in the vinyl or something. Being totally flat makes them look kind of boring, but stll much better than plain old gray.
Old Mar 21, 2004 | 05:45 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
You want your carpet to die? Atleast give it a chance to freshen up with some dye before you kill it, eh?
Old Mar 21, 2004 | 06:45 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
lol.... ok
starliner
Feb 9, 2016 08:18 PM
1992Z28!
Nov 19, 2015 07:33 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
