New window felts or restored ?
Old Mar 16, 2004 | 01:26 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Does anyone know of a place where I can get new window felts for third gens? I just need the the little things that have the fury velvet(?) material on them that guide the window up. Those that I have scratch my window and I intend to have the windows tinted again soon... can't have them scratching again.
Alternatively, does anyone know of a means of restoring these things ?
Old Mar 16, 2004 | 04:35 PM
LUVmy92's Avatar
Car: Camaro
Just gotta replace them. They arent too difficult to replace. Door panel has to come off, and also the weatherstripping at the front edge of the door pulled back (remove two screws) then the front track with the plastic triangle at the front of the glass has to be removed (3 screws). Once you get those off you will have access to the 5/6? screws that hold it on! Ok maybe a lil more complex then I thought. I belive they were all 10MM, had to use an open end small wrench on the ones blocked by the glass slightly (just push the glass towards the inside of the car and you will have barely enough room!
I really dont think they cost me more then 100 bucks? Maybe less cant find my receipt!
Hope this helps somewhat!
Old Mar 16, 2004 | 05:10 PM
88txiroc's Avatar
They run about $20 each from the dealer. I just replaced all four of mine, and it is much better. Less window rattle.
Old Mar 16, 2004 | 05:12 PM
LUVmy92's Avatar
Car: Camaro
4??? Mine were just two long strips. The part that is attached to the outer door skin.
Old Mar 16, 2004 | 07:23 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
and two on the inside of the window.
Old Mar 16, 2004 | 09:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Not sure if I interpreted the original post correct but, I believe the felts in question are the little 'L' pieces on the inner door that have felts on the legs of them (pic below). Not sure the name and they aren't in my collision guide.
You can go to the dealer and ask though. They do have detailed breakdowns that will most likely list that specific part.
Unfortunately, there are no part numbers stamped into the pieces so that limits my aid to this...
Old Mar 16, 2004 | 09:25 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i interpreted it as what you said, except i dont know anywhere else to get them besides the dealership.
Old Mar 16, 2004 | 10:09 PM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
If they're the things inside then I believe 1 A Auto sells them for around $10. http://www.1aauto.com/1A/Weatherstri...d/RPCA185/3682
Old Mar 17, 2004 | 11:17 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Man when I saw that I was about to order them but the shipping is 6 bucks that seems allittle much for them considering they would fit in a oversized envolope.
I think I will check the dealership before I order them now.
Old Mar 17, 2004 | 11:18 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Is the felt part different that the outside window rubber that attaches to the door?
Old Mar 18, 2004 | 08:17 AM
Car: 1987 IROC Z
I don't suppose you had a part number for them did you ?
Old Mar 18, 2004 | 08:20 AM
Car: 1987 IROC Z
I wonder if that kit will cover both doors.... I'll call them today and find out. If you hit the dealership, get a part number on the felts.
Old Mar 18, 2004 | 09:40 AM
88txiroc's Avatar
Try this: 20192983. It is called a stabilizer.
Thomas
Old Mar 18, 2004 | 10:40 AM
3gc's Avatar
3gc
Car: Z28
These are the outer window sweeps that attach to the door...
10124264 Right side
10124265 Left Side
$19.63 each from gmpartsdirect.com
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
mrbird
Oct 20, 2015 03:43 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
