Garbage inside door???
Old Mar 17, 2004 | 03:43 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
When I first got my IROC I took off my D/S door panel to replace my door lock. At the time, both my doors when shut sounded like there was broken glass in them. I took the first door panel off and there was what looked to be melted plastic in the door itself.
It looked like someone had taken plastic melted it and let it form little clumps.
Any idea what this could be? I doubt the door panel has been off recently if at all before...
Wierd thing is, they are redish and some of the bits look (IIRC) to have the same red color as my car.
Any idea what the hell that is? I'm gonna take off my P/S door panel this weekend and get the other crap out.
Old Mar 17, 2004 | 08:01 PM
XSVortex's Avatar
When I first got my car, i took off the door panels.... found about 3$ in pennies in the bottom. Yours sounds like maybe an electrical connector broke off, or somehow plastic got sucked between the weatherstripping and window. either way, wouldnt worry too much about it, unless something stops working . At least you dont have a piggy-bank car like mine (also found like 2$ in pennies in the spair tire compartment, and a bunch more under the center console).
Old Mar 17, 2004 | 10:11 PM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
I think what you found is some seam sealer,My car has it also.
Old Mar 18, 2004 | 11:41 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Whats it for? I can't believe how much of this crap there is in the door!
Old Mar 18, 2004 | 12:14 PM
The factory used it to fill in small gaps between sheetmetal.
Also I've seen cars that have been I think it's call Zbarted.
Where holes are drilled into varies body panels and a wand with a hole in it is inserted wich sprays out a undercoating type stuff to protect areas where water collects to prevent rust.
Its easy to spot cause you'll have plastic plugs about the size of a dime to fill in the holes.They'll be in your door jams along the top of your rocker panel and on the end of the door itself.
Old Mar 20, 2004 | 04:54 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
I thought that stuff went between the door skin and the crash bar
Old Mar 20, 2004 | 05:05 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
yeah i got those things too. BUt mine are huge. Like the size of a golf ball almost(maybe 3/4 the size)
Shane
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Fronzizzle
Sep 8, 2015 12:10 PM
NiG
Sep 7, 2015 11:25 PM
