softening/sealing glass to rubber seals
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
softening/sealing glass tighter to rubber seals
got a problem with a glass top having high pitch wind noise at front center of the glass when are traveling higher than about 35 or 40mph speeds, the seal that the glass lays on doesnt press against underside of the glass hard enough to prevent wind noise,
what to use when softening and/or swelling the rubber glass weatherstripping like this is needed to be done in order to prevent air leaks ?
thanks for anything
thanks for anything
Pac J
May 17, 2020 10:44 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Dragonsys
Sep 25, 2015 03:51 PM
