t-top help
Old Apr 22, 2004 | 04:49 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
t-top help
well my t-top on my drivers side has been rattleing for the longest time now and i finally got some time to tear into it and see why. well there are these larger plastic peices on the metal rod that holds the t-top down but on the back it was slid all they way in. i noticed that the front one was using a spring/clip combo to hold it in place. i need a p/n for this or any other ways to fix it. can anyone get this for me?
Old Apr 22, 2004 | 07:08 PM
jmd88iroc-z's Avatar
Car: '88 IROC-Z
Engine: 305 tpi
Transmission: 700r4/OD
Try the junk yard. Where I leave, old t-tops are all over the yard for some reason. If not, try ebay.
Old Apr 22, 2004 | 08:51 PM
92MaroRS's Avatar
i dont want a new t-top i just need the spring and clip p/n so i can fix it. mine are in great shape other wise. and only leak in one spot and i know why and how to fix it so no need for a different t-top just need what i mentioned before.
Old Apr 22, 2004 | 09:38 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Right, but he was saying go to the yard and take one apart.
Old Apr 23, 2004 | 08:04 AM
92MaroRS's Avatar
thats the hard part. there isnt any junk yards withing an hours drive. that i know of so im kinda screwed.
Old Apr 25, 2004 | 03:30 AM
Car: '88 IROC-Z
Engine: 305 tpi
Someone at GM should be able to tell you where you can get the part you need (since they don't carry ANYTHING we need anymore). I'm not sure what you're problem is but, I've fixed some of my leaks with an adhesive similar to roofing cement but, it's made for weather stripping and t-tops (I can't think of the name of it right now). You can get it at most parts stores. I'm not talking about "gobbing" it all over and making a mess. I mean apply it under the metal parts (where only you know it's there). Hope this helps.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
