85-90 T/A gfx
Old Jun 5, 2004 | 03:45 PM
fbody4me's Avatar
Car: 1980T/A,1987GTA,1989 GTA conv
85-90 T/A gfx
I did a search and still can't find the info I need.Could someone please help?I have a 83 T/A that I want to put the 85-90 ground effects on.The problem I have is that I can't find the part number for the metal support that is spot welded to the rocker panel from the factory.There are two metal supports per side,one welded to the rocker and another that bolts to it(#10037110).I have called several dealers and they don't show the piece that is welded to the rocker panel,they just show the second piece 10037110 witch is discontinued.Also was wondering if someone knows were I might be able to find the second(10037110)support?I have spent hours at the junk yards trying to find the second metal support only to break the studs off when taking them off.Any advise would be GREATLY appreciated.Thanks
Old Jun 6, 2004 | 11:16 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
i doubt that the welded piece would be available from the dealer any more either. Some people have made their own brackets to hold ground effects onto a car that never had them so you can do a search and see how they did it. Basically, I think they just used a standard L-bracket wherever a screw went. Also, if you have an 83 TA doesnt it already have brackets for ground effects? good luck
Old Jun 6, 2004 | 12:35 PM
fbody4me's Avatar
Thanks for the reply JeremyNYR.My 1983 T/A does't has the ground effects on it.It has the little fiberglass pieces in front of the tires that are barely noticable(red car with black on the bottom).I guess I could go to the junk yard and drill out the spot welds that hold the support on.That just seems like alot of work for a piece that probally would cost about 5 or 10 bucks.I was thinking that if I had the part number I would be able to find them somewhere even if they were discontinued from GM.Does anyone out there have a old GM parts book?
Old Jun 6, 2004 | 02:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Save yourself some $$ and just buy 2 pieces 1.5-2" x 1/8" x 4' flat bar and weld it to the rocker.
IIRC the stock piece (when it was available) was around $60-70 per side.
If you're determined to have the stock pieces, try using the link in my sig to find your #
Old Dec 28, 2004 | 11:19 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
The metal bracket part number is: GM10037111
Old Dec 29, 2004 | 09:46 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I would just hit the salvage yard with a drill to drill out the spot welds from the donor car.
Old Dec 29, 2004 | 11:46 AM
joetiger98's Avatar
Car: 89' Trans Am KARR Rep.
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 3.27 Posi Disk
Just do one small thing when ya get them on....Drill small holes in the bottom of the Gnd FX to let water out...water gets in & can't get back out....I have bad rust damage I need to fix because of this. Just so it don't happen to anyone else.
Joe
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
F-body-fan
Nov 4, 2015 06:13 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
