further discussion of firebird headlight mods
Old Apr 22, 2005 | 02:10 PM
  #151
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I made the hood skin using my steel hood and fiberglass ram air scoop as a mold. The underside of the hood will be made just like the top using the bottom of the steel hood as a mold, laying fiberglass over top of the bracing, etc.. Once I have the top and bottom pieces trimmed I'll epoxy them together with clamps.
Eventually I'd like to fiberglass most of the body panels on the car- including door skins, rear quarters, lower the side gfx about an inch, lower rear bumper cover 2" or so, etc. Not to get too far off topic tho..
The fiberglass hood and bumper will make it easier to mold in the headlights of your choice. Besides being itchy and having cancerous dust, fiberglass is a good choice vs. cutting up a perfectly good steel hood or trying to plastic weld on the factory front bumper cover.
-Ben
Old Apr 23, 2005 | 01:02 AM
  #152
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Originally posted by 1983Fbody
Redraif Is there any markings or numbers on that relay you got with the kit, it would be nice just to go to the parts store and get that specific one so I can follow your directions instead of messing with a relay from the junkyard. thanks,
-Ben
87: output to item
86: input (signal wire)
85: ground
30: power
Those are the numbers that should be on the bottom of the relay where the prongs are. It is a universal relay...nothing special...any parts store should have it. There maybe some additional or letters after the numbers, but I'm sure you get the idea!
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
