Filling In Emblems, Shaving, Need Help :)
Old Jun 25, 2004 | 01:12 PM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
Hey I did a search and surprisingly didn't find much on the topic, but I want to fill in all the emblems.
The nose emblem - Just want to fill this in so it looks like it never had a camaro emblem there. What would I use? Some type of fiberglass filler?
The Ground Effect Emblems - Now this one seems a lot harder because you have to put screws through behind the sticker. So could I just make some kind of replacement that sits more flush to the car, or just paint over the stickers or what?
The Rear - Without the sticker it's not even that bad looking, but it still has a somewhat of a chevy bowtie looking thing in the rear. What I'd want to do is just fill it in so it's a solid stripe all the way across, so same thing as the nose.
And are these things that a person with no fiberglass experience or body work could do? I'm willing to learn new things, and can be pretty crafty, just no past experience.
Old Jun 25, 2004 | 05:58 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I did all mine with regular bondo last year when I was in a rush to paint my car...I used fiberglass on my antenna hole and the rest was just bondo...Front nose still looks perfect...I noticed some crackin on the side ground effects, I think its mainly cause I did them so quick If I would've worked it out more I think I would've been fine. I probably should've used some fiberglass reinforced filler, That would've done the trick on the side peices.
Old Jun 25, 2004 | 06:39 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
use gorilla hair, or fiberglass is what it is, thats what i used on my emblem hole, go to my car domain site, not much there, havent updated in ages, but you hav a few pics of how to do it on there,
Old Jun 25, 2004 | 10:54 PM
stiers's Avatar
Don't use bondo, don't use fiberglass.
You missed this thread in your search:
https://www.thirdgen.org/techbb2/sho...hreadid=194105
Deadbird says exactly what you need to do the job.
Old Jun 25, 2004 | 11:00 PM
jay92,85,79's Avatar
Car: 85z28,
If u have a 82 to 90 camaro for the gfx u can use filler but make sure all the paint is off even in the hard to sand places.bondo does not stick to paint.If it a 91 92 gfx go to a autobody supply store. And get some kind of bumper repair. At the shop i work at we use a brand by evercoat. But they prettymuch work all the same. And than use that on the front and back bumper.U do not want to use bondo or fiberglass on the bumpers.Once bondo dries its as hard as a rock (no flex)..
Old Jun 26, 2004 | 07:23 AM
SLOWFIVEOH's Avatar
Engine: 355
Your exactly right...The stuff that deadbird said would work great on the nose emblem...Alot better then bondo which I used cause I was in a hurry....But I havent run into anything so there is no flexing in my nose so its doin allright...But if you have 82-90 Gfx some glass reinforced filler will be fine...Since the whole piece is glass anyway!
F-body-fan
Jan 12, 2023 01:49 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
2012sergen11
Oct 13, 2015 07:38 PM
meeklay812
Oct 1, 2015 03:46 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
