Yet another 4th gen swap question
Old Jul 1, 2004 | 07:07 PM
Tack25's Avatar
Car: 1992 Camaro RS
Engine: 350 V8
I know as repetitve as it is I have searched and have not found exactly what needs to be taken out of a 4th gen car for the dash/console swap. I know I must take out the dash itself, what about the heater box, or all the other essentials? Thanks
Old Sep 14, 2004 | 07:39 PM
wlsmoku's Avatar
Car: 1988 GTA
I'm trying to find the same info - I'll keep you posted on what I find
Old Sep 14, 2004 | 09:52 PM
whitebird312's Avatar
Car: 90 trans am
Engine: 5.7
Transmission: auto
Re: Yet another 4th gen swap question
i just did swap on console as far as heater boxs use same as you have just need dash cluster in side harness for plugs to wire to and climate control im in process of doing this myself i did consle first email me ill give complete details on console swap good luck
Old Sep 14, 2004 | 11:24 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Im almost finished with my swap so Ill try to remember all you need. A/C ducting, obviuosly all the trim and glove box, any connector that go to anything on the dash with as much wiring as possible(HVAC, Headlight, dimmers, fog, trunk button, guage) top dash panel, under dash panels if you want, Grab the fuse box if you feel like switching your out to the 4thgens easier location (at least on the 4th Birds) Thats about it.
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
