will glass t-tops fit on my car if it originally came with plastic ones?
Yes!
They are both the same shape and have the same connecting pins and latching mechanism.
Quote:
Originally posted by f1ls1
Yes!
good to know...thanks for the respose. i have one more question though. Does the year matter? If so what years are compatable with my car?Originally posted by f1ls1
Yes!
All years are compatible.
Quote:
i know it sounded like a stupid question...but somebody told me otherwise and i wanted to make sureOriginally posted by 87WS6
as far as i know all 82-92 t-tops work, as long as they r pin or hook (whatever your car is) i'd like to know where i can get a pair of lexan (plastic) T-tops. e bay...i don't think half those people know what they r selling. one guy sed his T-tops were good for cutlass f-bodies and ragals... LOL o well
will firebird t-tops fit on camaros?
vernw
close
- Join DateJul 2003
- LocationDallas, TX area
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car91 Formula WS6 (Black, T-Tops)
- Engine383 MiniRam (529 HP, 519 TQ - DD2K)
- TransmissionBuilt '97 T56, Pro 5.0, CF-DF
- Axle/Gears4.11 posi Ford 9"
- Liked:0 Times in 0 Posts
Just be aware that there are 2 sizes of pin type latching as well, so that means there are actually 3 different versions of t-tops..... not counting glass vs. lexan.
Quote:
as stupid this question sounds...how can i tell the difference between them?Originally posted by vernw
vernw
close
- Join DateJul 2003
The latch type have a hook that locks into the body. The two pin type latches have different diameter pins. Just measure yours (if they're pin type) and make sure the new set is the same diameter.
ok thanksOriginally posted by vernw
Yeah I forgot to mention that. Didn't the pins change in 1985?Originally posted by vernw
Actually, the pins are the exact same size, it's just that the newer style have a spring loaded plastic "outer" sheath around the pin that acts as alignment assistance, so ANY pin type t-top will work, they will just need to be aligned.
HTH!
HTH!
Yeah, my 84 has hooks.Yeah I forgot to mention that. Didn't the pins change in 1985?
Quote:
my 84 has pins.Originally posted by KEVIN G.
Which cars came with hooks and which came with pins?
You may have a Hurst/Cars & Concepts aftermarket T-top roof. Do you have a molding (like door edge molding) around the perimeter of the roof opening?Originally posted by KEVIN G.
Hrmmm I think I have hooks and not pins. And I thought mine was factory...
I think we need clarifying pictures of the different types of t-tops
No, mine are original, glass all the way to the edge.You may have a Hurst/Cars & Concepts aftermarket T-top roof. Do you have a molding (like door edge molding) around the perimeter of the roof opening?
I've seen some that are hooks (seemed to be pre-86.) Mine didn't even have locks.
The molding I referred to would be on the body edge where it met the T-top opening, not the glass panels themselves. The edge above your door glass, is it 2" wide or 4"?Originally posted by KEVIN G.
approx. 1.5 in.
That's OEM Fischer tops, just never seen the hook type on 3rd gen cars....
