Speedo Question
Old Jul 25, 2004 | 01:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Speedo Question
I went from an 85 to 110 with no problems. I recently swapped in a 145 (I used the VSS that came with the speedo) and now the needle will bounce from 65 to 80 miles an hour at 70. Suggestions?
JamesC
Old Jul 25, 2004 | 02:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check your speedometer cable for binding, if that's not it, you have a bad speedometer head.
Old Jul 25, 2004 | 03:02 PM
JamesC's Avatar
Would some graphite spray such as Lock-Ease be beneficial on the cable?
JamesC
Old Jul 25, 2004 | 03:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It might help.
Old Jul 25, 2004 | 04:17 PM
JamesC's Avatar
I removed the 145 cluster, stuck the old VSS (I know, I know) back on, and shot some graphite lube in the cable. Now it's only bouncing, perhaps 5 mph, at 70. I don't know whether to try lubing one more time, since it helped, or simply stick the 110 speedo head back in.
JamesC
Old Jul 25, 2004 | 04:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could try to lube the entire length of the cable too.
My speedometer bounces a little and reads low right now becuase I really hate pulling the head out to get at the cable. :P
Old Jul 25, 2004 | 04:53 PM
JamesC's Avatar
Is removing the cable as simple as pulling and twisting until it comes free? How about reinsertion?
JamesC
Old Jul 25, 2004 | 05:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just pull it straight out, it should come out without much fuss. If you want you can disconnect the cable housing at the transmission too and spray some brake cleaner down from the top to flush out any crud that's in there first. When you reinsert the cable, you might have to turn it a little to line the square end with the hole in the gear in the transmission. You might also need to turn the shaft on the speedometer a little to get it to seat fully when you install the head too.
Old Jul 25, 2004 | 05:33 PM
JamesC's Avatar
Cool. I may put the 110 in again tomorrow to see what occurs. If it too suddenly has a problem, then surely the cable is at fault (though how swaping one speedo for another would cause difficulties is beyond me). If it functions as well as it always did, then the 145 has a problem. Because the 145 improved after the lubing, I'm intrigued at what the results might be.
JamesC
Old Jul 26, 2004 | 09:39 AM
JamesC's Avatar
FYI.
I swapped the 110 back in this morning. It's right on the money, so the 145 speedo head must have a problem of some sort. I think I'll see what my GM parts man says about sending it for repair--may be cost prohibitive however.
JamesC
Old Jul 26, 2004 | 11:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I've been quoted something like $300 Canadian before to repair thirdgen speedometers.
Old Jul 26, 2004 | 12:49 PM
JamesC's Avatar
Ouch!!! Well, I'll pick up another somewhere sometime before I cough up that kind of dough. The parts man is supposed to be getting an idea of the cost this afternoon.
JamesC
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
beachrodder
Aug 7, 2015 04:27 PM
