did the compase style speedo come in 85-86 z's?
Old Aug 1, 2004 | 06:17 PM
1FSTGTA's Avatar
I was looking at buying a 85- 86 z28 I noticed it had the same speedo as the 82s have ,did they come with this? Looks like soemtignyuo would find in the cockpit of a plane had the double needle with kph to one side and mph to the other
thanks
Old Aug 1, 2004 | 06:58 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
So do you know Dustin?
Or you just like his car enough to put it in your signature....
...as for the speedometer... I did a quick search on google and a few sources said that the double needle was done away with in 85.
http://www.camarosource.ca/php/camar....php?year=1985
http://www.camaro3rdgen.20m.com/1985.html
-Bud
Old Aug 1, 2004 | 08:27 PM
1FSTGTA's Avatar
I just like the car ALOTE
thanks for the info
Old Aug 2, 2004 | 02:00 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
i got a dual speedo cluster if u want, its out of a 83 though
Old Aug 2, 2004 | 02:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the car has the double needle speedo, either it's been swapped in, or the car is 82-84, not 85-86. Either way, there are probably questions to be asked.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bschmale66853
Sep 30, 2015 08:11 PM
