whats wrong with my seat?
Old Aug 2, 2004 | 01:30 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
my front drivers seat cant move forword or back..its stuck in one spot. nothing happens when i pull the thing thats suppost to make the seat move, also it feels like it has no tension. can someone tell me whats up with this and how do i fix it??
thanks
Old Aug 2, 2004 | 03:32 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Check your rails. Theres a wire that connects to the slide lever. Check to see if the wire broke or came loose.
Old Aug 2, 2004 | 04:27 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I second that, I had the same problem with my 4th gen seats. Very easy to fix though.
Kevin
Old Aug 3, 2004 | 01:18 PM
Car: 1983 Z28
Transmission: TH350
ya the wire that connects to the slide lever is loose, when i pull the lever all the way its still not enough to pull the wires cuz its to loose. how do i tighten it?
Old Aug 3, 2004 | 01:19 PM
Car: 1983 Z28
Transmission: TH350
ya the wire that connects to the slide lever is loose, when i pull the lever all the way its still not enough to pull the wires cuz its to loose. but its not broken> how do i tighten it?
HP52TA
Feb 3, 2018 10:51 PM
Dyno Don
Jan 24, 2016 08:24 AM
MORREALE5
Sep 13, 2015 09:01 PM
sandman92084
Sep 12, 2015 10:27 PM
MORREALE5
Sep 10, 2015 08:58 AM
