filling bolt holes on door
Old Aug 18, 2004 | 02:07 PM
Cole's Avatar
I have a door off of a Trans Am that I want to put on my Firebird. There are several small holes in the panel from where I removed the ground effects. Are these large enough to need welded? Can I fill them with body filler, and if so, does it have to be waterproof/fiberglass filler?
Old Aug 18, 2004 | 03:04 PM
jan-erich's Avatar
Car: -84 Trans am 15th anniver
Engine: 325hp 305
Transmission: th700r
theres only one way to make it the right way. weld it
Old Aug 18, 2004 | 03:20 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
tap or grind then weld and grind some more and use lightweight filler or cream to smooth it down perfect
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
