got a question about door handles
Car: 91 z28
Engine: 305 tpi
my handle on the inside of my car broke the other day. i took apart the door and noticed that the handle is riveted to the door frame on the inside. if i drill it out, would a nut and bolt be good enough to put back in there to hold it? or should i rivet it again?
thanks for any help.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes use hardware, screws or bolts whatever fits tightest and still s able to pass through in order to avoid possibility of side slop after its blted or screwed on
the gm trucks ones are screwed to the doorskins with three screws, they been doing that since way back when since at least 63 i know, they never break or come loose or anything
rivets are a PIA and cheap and weaker anyways, especially if are aluminum stem ones in which i think is what is used on the cars
so..
so..
Car: 91 z28
Engine: 305 tpi
well i got it fixed. i used nuts and bolts instead of rivets. it seems stronger already. hopefully it will last a long time. lol. it was a pain tryin to get the panel off cuz one bolt holding the arm rest on was a pain in the butt.
Car: Z28
Did you use some lock tite on that bolt? I used small (4mm?) allen head bolt and a wing nut, i couldn't get my hand back there and hold a regular one. Put some red locktite on it, that was over a year ago. Haven't had a problem with it coming loose or anything yet.
Car: 91 z28
Engine: 305 tpi
i used a normal bolt with a nylon but. i was able to get back there and tighten it. if it comes loose its a easy enough fix.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
