t top help
Old Sep 6, 2004 | 09:35 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
t top help
i have an 89 iroc that origionally had glass t tops. now it has lexan ones and i hate em. today i got a set of glass ones and they lock down tight to the car. the pass side one i had to adjust to get it to lock but the drivers sisde i didnt. my problem is now they leak like crazy. my lexan ones never leaked. i put the glass on and washed it and the seats were soaked. how can i fix this. i was thinkin about adjusting thw window stops so thw window will go up higher. they seem to be making a good seal. any help would be great. thanx
Old Sep 7, 2004 | 01:14 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
do yourself a favour and do a search....
there's all sorts of things about how to fix t-top leaks...
the rubber trim on the t-top is adjustable front/back, try that.
make sure it's not deformed, you might have to replace it. You could probably use the same rubber from your lexan ones....
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
rsrookie
Sep 5, 2015 07:08 PM
