Side Mirror
Old Sep 16, 2004 | 09:35 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Side Mirror
Is it possible to remove the glass from the plastic mounting bracket for a side view mirror? I went to a wrecker and found a broken one, took it apart and fount that it is attached to the plastic bracket with a silicon type adhesive. How would you go about getting in there to release the mirror from the adhesive? I ask only because I have power mirrors, one of which is broken and am in possession of a manual mirror, so I was hoping to make a swap, but the brackets are not interchageable.
Old Sep 16, 2004 | 09:43 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
stop by your local glass shop they can install a new cut to fit one for a few bucks..
jeff
Old Sep 16, 2004 | 09:50 PM
Kevin84Z28's Avatar
Is there a certain type of adhesive?
Old Sep 17, 2004 | 01:10 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
I HAVE THIS SAME PROBLEM, HOW DO U GET THEM OUT????
Old Sep 17, 2004 | 01:47 PM
Kevin84Z28's Avatar
I dont think they were meant to come out actually. The plastic piece will unscrew from the mirror housing but the mirror and plastic are mated for life, unless you break the glass out and put in a new one with adhesive. There may be some trick to getting the glass out without breaking it but it seem with just a bit of manhandling the mirror chips or cracks. I was thinking of just sinking the whole assembly into some solvent and seeing if the adhesive dissolves.
Old Sep 17, 2004 | 01:51 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
YEAH. ALOT OF WORK, I'LL JUST BUY OR LOOK FOR NEW ONES, THANKS......
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
buckshot63
Sep 3, 2015 08:10 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
