Anyone build a homemade paint booth
Old Oct 10, 2004 | 11:25 PM
ross0310's Avatar
I was wondering if anyone has built a paint booth in their garage or whatever and how you did it. Ive got a detached garage and have been thinking about how to make a paint booth in it with venting, but i dont really have a good idea of how to start. i was thinking pvc and heavy plastic and some good exhaust fans. i only plan on using it 2 maybe 3 times a year. any suggestions
Old Oct 11, 2004 | 02:38 AM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
I made a booth in my shop in my basement, just some plastic drop cloths hung from the ceiling with weights on the bottom, squarish, aprox 5 feet by 5feet maybe. I removed an old window and put in an exhaust fan with filters behind it. For the filters I use just regular heater filters available at home depot cheap. Be sure to filter the air leaving, or you'll end up with paint all over the place. For my purposes, it has worked really good with all the parts I have painted. Its a good idea if you want to paint a good amount of parts and dont want to paint outside all the time. If i find some time ill post a pic.
Old Oct 11, 2004 | 12:04 PM
ross0310's Avatar
thanks that was kinda my idea but i wanted some other opinions.
Old Oct 11, 2004 | 03:29 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Don't forget to filter the incoming air as well, you won't want dirt in the paintjob...
Old Oct 11, 2004 | 07:47 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
make a frame for the booth, pvc pipe wood whatever, whatever size you want, the biggest you can do in the garage i suggest, plastic sheeting and seal it to the frame use glue if you have to, it should be air tight as it can be or as you can make it, get about 4 good size fans, teh biggr the better, face them to pull air out of the booth on one end and jus install some filters on teh opposite end to filter the incoming air, ofcourse you have to have a way of gettin in so desigh a door fram and again, air tight, air entering one side and leaving the other....thats it....just like my booth at work...same concept at least.....
Old Oct 11, 2004 | 07:58 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
https://www.thirdgen.org/techbb2/sho...ht=paint+booth
filter air in filter air out wet floor, good door that was my down fall , and hairspray the plastic walls helps with dust control as stuff sticks to it.
Jeff
Old Oct 11, 2004 | 10:44 PM
ross0310's Avatar
thanks for the info, and pics, I think I will go with the pvc and make a building inside of a building in my garage, good thing is ive got a garage door on each end so plenty of area for the fans to get air from.
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
neekolzun
Aug 24, 2015 04:59 PM
