92 Z Door Panel repair or replace....
I cannot find a door panel replacement that does not have the top holes pulled out or the backboard is not bent or coming apart.
My point is I would like to do one of two things:
1. Repair the panels I have and somehow fix the holes so the door moulding will stay put. What do I use and how do I do it?
2. Make new panels and create a different design with the existing material and pieces or create a different design and placement of materials. Has anyone done this, if so with what and how?
Can anyone answer these two questions with directions or links?
Thanks,
Jim
Thanks,
Jim
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
make them out of thin plywood. cover them in your choice of materials
Car: 1992 Z28 camaro
Engine: 5.7
1992 Door panels
There are some door panels for sale in the classifieds off a 14,000 mile 1992 Z28. They should be in excellent conditoin. Search for 1992 Z28 door panels and you should find them easily.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
