Can someone tell me if this will work?(Door panel repair)
Old Nov 9, 2004 | 02:56 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
When I first got my car 5 years ago, I was a novice and rushed into the project without thinking. I tried to take the door panels off, and pulled off the upper black piece of the panel and seperated it from the lower panel. The little holes in the cardboard?? on the top of the door panel that the upper piece attaches to and all ripped. Rather than buy new door panels, I though about just buying the new top piece from say Haws and then just use some cardboard and make an upside down U type shape and staple it to the cardboard of the door panel so the upper piece has something to attach to. Do you think this will work or am I better off buying new door panels as well? Thanks for any opinions/suggestion, Paul Moore
Old Nov 9, 2004 | 05:36 PM
MNformula350's Avatar
The other thing you could do, is just put them both on the door seperatley, the clips on the back of the door panel will hold it solid and the black piece mounts by the clipe on the top anyway. it should look fine. i havene't done it but in theroy it should work
Old Nov 10, 2004 | 03:34 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
i riped mine a while ago, you'd never be able to tell.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
