Door panel moulding clips?
Old Nov 29, 2004 | 11:59 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Okay, I tried to search and I wanted to ask how do I get off those acorn nuts that hold the upper trim panel, to the door panel? The acorn nuts are installed upside down on mine, (maybe built just before a strike) Any ideas please
Tim
Old Nov 30, 2004 | 12:02 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
slowly twist them off either with your fingers or a pair of pliers.
Old Nov 30, 2004 | 12:38 AM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Cool, I just wanted to make sure I wasn't crazy. Thanks
Old Nov 30, 2004 | 01:48 AM
Morley's Avatar
The best way to remove them is: Find the allen key that fits in the nut, then go the next size down. Take a piece of thin aluminum and bend it around the allen key using vicegrips to get all of the bends, then cut off any excess. Slide your new "wrench" down the allen key so the "wrench" will engage the nut, use a small hose clamp to hold the "wrench" on the allen key. Now unscrew the nuts and when you are ready to install them you'll have something better than plyers.
Old Nov 30, 2004 | 12:26 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Good call thanks a lot!
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
