Shaving Gas cap Door ?
Old Jan 19, 2005 | 06:38 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
What guage sheet metal should I use. also I am installing a fuel Cell and what guage sheet metal should be used to Finish Interior Floor around fuel cell
Old Jan 19, 2005 | 06:41 PM
crazyn8's Avatar
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
22-24 ga. will work. My vote would be 22 ga.
Old Jan 19, 2005 | 07:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Most body sheetmetal is 20ga which, is what i would try to stick with. 22ga would be min. and 24ga... might as well glue tinfoil over the cap opening
Old Jan 22, 2005 | 11:54 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I just got a junk door form a junk yard. was badly mess up so they just let me cut off the Outer skin. Just cut my pattern out of it!
Old Jan 23, 2005 | 07:36 AM
turboclone's Avatar
Car: 86 t/a
Engine: 383 turbo world heads ect.
Transmission: t400
what i'm going to do is take an aircraft style locking fuel door assy from a sport bike and cut it into the factory fuel door. after it's done, weld it on to the body and fill smooth. that way i can retain my factory stock local of the new fuel door. looks good too.
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
Out-Cast
Aug 23, 2015 06:33 AM
chazman
Aug 22, 2015 02:01 PM
madsv1000
Aug 20, 2015 06:45 AM
