Can I wetsand a metallic?
Old Feb 9, 2005 | 11:42 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I just got my bird painted a metallic red at Maaco. They painted OK, but lots of orange peel.
Can I wetsand a metallic paint? Should I use 1500 or 2000?
Old Feb 9, 2005 | 11:54 AM
Ringmaster72's Avatar
Car: 1989 IROC
Is it single stage or base/clear? If it is base/clear, then it does not matter. If it is single stage you can still do it, but you might bite into metallic under the surface and cause it to be splotchy.
Old Feb 9, 2005 | 12:09 PM
Car: 89 GTA
Axle/Gears: 4.10
Just called em and he said it's a single-stage.
So I guess wetsanding is out. He said he wouldn't recommend me westanding it. Do you think I can improve the orange peel with my Makita rotary with a wool pad and cutting compound?
Old Feb 9, 2005 | 02:25 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
Transmission: TH700 R4
Axle/Gears: 3.08 drum
i wouldnt wetsand it, there's a reason maaco doesn't do any wetsanding themselves.
Old Feb 9, 2005 | 04:38 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Nope, you're still in the same boat... If you use a heavy enough compound to cut the peel, you'll destroy the metallic suspended in the enamel.
Old Feb 9, 2005 | 04:41 PM
Car: 89 GTA
Axle/Gears: 4.10
OK, so I'm screwed about the peel , oh well.
I guess I learned an important lesson about paint jobs!
Old Feb 9, 2005 | 05:51 PM
jay92,85,79's Avatar
Car: 85z28,
how much is there? I did a chevelle it had a very little orange peel. I just wetsanded it real lightly. And buffet it. There is olny one spot that looks bad. But how i look at it if u wanna get rid of it the only way is to repaint it. So u might as well try it.
MrPackstin
Oct 25, 2017 08:09 PM
Night rider327
Feb 25, 2016 09:50 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Numbah-1
Oct 2, 2015 08:27 AM
sjorgens
Oct 1, 2015 07:54 PM
