to buy or not to buy?
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
i can buy a 1989 GTA 350TPI with t-tops the car is in good shape ($400.00) it does have a running problem but i can figure that out and the seats are different color in the front but the main problem is i checked the car out and theirs some holes and a good amount of rust under the rear wells my ? is their a way to fix this? and how much would it cost? and what needs to be done?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
For the most part, if the car has substantial rust (can see from the inside out or vice-versa) and you or a friend cannot do the fab/welding work yourselves... from a cost standpoint.. the car will be more valuable as parts.
If cost is no object to pay for the labor... then asking a rough estimate is a waste. Cost is equivilant to how bad the problem is. W/o pictures, it's difficult to even begin to give a cost estimate. Depending on severity based on visuals, it could be a 1hr job or a 10hr job,
Car: 1989 GTA
the car itself is not rusty at all just behind the rear wells has a couple of holes i know you cant tell me what to do without pictures.im willing to spend 4-5 hundred to fix the problem.so what has to be done do you have to weld new pieces in from another car? or can it be patched? i was thinking of using por-15 to seal it up.anybody in new york,jersey,mass,penn that can help me?
Originally posted by 1987gt
the car itself is not rusty at all just behind the rear wells has a couple of holes so what has to be done do you have to weld new pieces in from another car? or can it be patched?
Car: 1989 GTA
its not the quarter panels its right behind and all above the rear tires.it must be a common problem because my GTA is starting to get some rust in that area but im going to use some rust coating and then have it z barted.if you look above and around the rear well you can seem a seem and its rusted there and all above the well area. maybe it can just be reapired.for 400.00 this car is cheap for a t-top gta 350.my car doesnt have the t-tops thats why i like this one also 2 GTAS would be nice to have lol.
Engine: TPI 305/ v6
Well.. I had a longer reply but, for reasons, here's a cliffnote....
For the price, but it anyways. You can easily make your $ back if you decided to part it.
Rust with no holes can be stripped/blasted/converted and the cleaned metal re-treated to be "good as new"
Rust you can poke holes through or has holes already, needs patchwork. Depending on how far the cancer goes depends on the time and patch size.
Usually, if there's a good amount of rust in one area of the car, just as good of a chance for it to be in more places too.
Under the gfx, floorpans and inside the doors are 2 good places to breed rust as well.
It's ultimately up to you if you feel up to the task to 'restore' the car. I wouldn't pass up a $400 car though...
Car: 1989 GTA
thanks bird thats the kinda help i was looking for i feel the same way i hate to pass it up im just trying to figure out how much it will cost me i know its imposible to guess since you cant see it.anyway i think your right i really cant loose because i could allways use the as a parts car for my other GTA.a guy is supposed to buy my honda tuesday so i think i will go pick that car up if you know anyone in new york,jersey,penn or mass thats good with body work and wants to make some cash send him my way.again thanks for your help its greatly appreciated.and for all the other third geners its getting warm soon get ready to smoke up them tires.
