Hood Modifications
Old Feb 15, 2005 | 08:31 PM
CamaroThunder84's Avatar
Car: Z28 Camaro
Engine: V8 - 5.0
Hood Modifications
On the 84 Camaro hood, there are plates covering two slots in the middle of the hood. I want to to modify the air intake to have mechanical flaps in places of those two plates and divert the air intake from the pront of the car... Has anybody done this??? Does anyone know where I can order the parts???
Old Feb 15, 2005 | 08:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could try looking for the parts for an 82-84 crossfire car, they had this from the factory.
Old Feb 15, 2005 | 08:40 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
I'm pretty sure that the firebirds with the powerbulge hood had some sort of mechanical flap that opened when the throttle was pressed something like 1/2 or 2/3s the way down. You might want to start looking into that system and fitting it to your camaro.
-chillen
Old Feb 15, 2005 | 08:45 PM
topless 88's Avatar
Car: 88 iroc convert/87 formula/91 Z28
Engine: tpi 305/305 carb/305 tpi
Transmission: 700R4x3
Axle/Gears: 3:73/323/273
That was an option on the 82-84 cross-fire cars. Those hoods look the same as the one you have and are made of 'glass. They are still around, you just need to look. The 'glass hoods had a problem with seperating so you need to look for that. Maybe someone here has one they would sell. Hope this helps.
Old Feb 15, 2005 | 09:26 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
The cross fire was only an option from 82-83. Those hoods are pretty hard to find...
Old Feb 17, 2005 | 09:10 AM
Derth Deboblo's Avatar
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Guess me and my bro got lucky about a month ago when we scored one from the local 'yard for $20. One small crack and bad paint is all thats wrong with it.
-Derth
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
