Need help fixing GTA door panels
Old Feb 17, 2005 | 11:25 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Ok I bought some GREAT looking GTA door panels on ebay...they are in near perfect condition, except for the top holes that are used to attached the top door trim. Most of them have torn through. Keeping in mind that the backing on these panels are much more rigid than the regular door panels...anyone have any ideas on how to fix this? I was thinking either some how attaching metal washers on each side of the card board......or creating a bridge on the top of each hole...or attaching a strip of aluminum or something all across the top with the holes drilled in the same location....or maybe just fiberglassing the holes...I dont know. What is the EASIEST way...and what is the STRONGEST way?
Also, are the top trim peices the same for all the cars?
Old Feb 17, 2005 | 10:35 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
yes - the top trim pieces are the same for all cars. I've replaced the ones on my GTA panels.
As for the ripping, I'd just use a long sheet of alluminum glued to the back of the panel.
Old Feb 17, 2005 | 10:41 PM
mult68's Avatar
Engine: 305 TBI
what kind of glue should I use?
Old Feb 22, 2005 | 10:04 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
mine have done this as well. what ive done it totally seperate the two pieces.
1. door panel
2. top weatherstrip and trim.
bolt the door panel on, then "lock" the top piece in place. it will look factory when installed.
good luck.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
